Nginx 404 not found with staticfiles.conf magento
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by reallove0810, Jan 3, 2015.
  1. reallove0810
    reallove0810 New Member
    25
    3:06 PM
    1.7.9
    5.5.41
    Hello, I using magento with the following conf. Everything is very good and sometime 502 bad gateway.
    I must add # before "include /usr/local/nginx/conf/staticfiles.conf", because when include staticfile.conf, i can access only homepage, other link is 404 not found. Any body can explain it?
    #server {
    #    server_name domain.com www.domain.com;
    #    return 301 https://$server_name$request_uri;
        listen 80;
        listen 443 ssl spdy;
            ssl_certificate      /usr/local/nginx/conf/ssl/myphampolacom/ssl-unified.crt;
            ssl_certificate_key  /usr/local/nginx/conf/ssl/myphampolacom/ssl.key;
            ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
            ssl_session_cache      shared:SSL:10m;
            ssl_session_timeout  10m;
            ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
            # nginx 1.5.9+ or higher
            # http://nginx.org/en/docs/http/ngx_http_spdy_module.html#spdy_headers_comp
            # http://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_buffer_size
            # spdy_headers_comp 0;
            # ssl_buffer_size 4k;
            # enable ocsp stapling
            resolver 8.8.8.8;
            ssl_stapling on;
            ssl_stapling_verify on;
            #ssl_trusted_certificate /usr/local/nginx/conf/ssl/myphampolacom/ssl-trusted.crt;
        server_name domain.com www.domain.com; ## Domain is here twice so server_name_in_redirect will favour the www
        access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
            index index.php index.html; ## Allow a static html file to be shown first
            try_files $uri $uri/ @handler; ## If missing pass the URI to Magento's front handler
            expires 30d; ## Assume all files are cachable
        location /blog {
        try_files $uri $uri/ /blog/index.php?q=$request_uri;
        location /wp {
        try_files $uri $uri/ /wp/index.php?q=$request_uri;
        ## These locations would be hidden by .htaccess normally
        location ^~ /app/                { deny all; }
        location ^~ /includes/           { deny all; }
        location ^~ /lib/                { deny all; }
        location ^~ /media/downloadable/ { deny all; }
        location ^~ /pkginfo/            { deny all; }
        location ^~ /report/config.xml   { deny all; }
        location ^~ /var/                { deny all; }
        location /var/export/ { ## Allow admins only to view export folder
            auth_basic           "Restricted"; ## Message shown in login window
            auth_basic_user_file htpasswd; ## See /etc/nginx/htpassword
            autoindex            on;
        location  /. { ## Disable .htaccess and other hidden files
            return 404;
        location @handler { ## Magento uses a common front handler
            rewrite / /index.php;
        location ~ .php/ { ## Forward paths like /js/index.php/x.js to relevant handler
            rewrite ^(.*.php)/ $1 last;
        location ~ .php$ { ## Execute PHP scripts
            if (!-e $request_filename) { rewrite / /index.php last; } ## Catch 404s that try_files miss
            expires        off; ## Do not cache dynamic content
            fastcgi_pass   127.0.0.1:9000;
            fastcgi_param  HTTPS $server_https;
            fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
            fastcgi_param  MAGE_RUN_CODE default; ## Store code is defined in administration > Configuration > Manage Stores
            fastcgi_param  MAGE_RUN_TYPE store;
            include        fastcgi_params; ## See /etc/nginx/fastcgi_params
      #include /usr/local/nginx/conf/staticfiles.conf; 404 not found
    Default staticfiles.conf
        location ~* \.(3gp|gif|jpg|jpeg|png|ico|wmv|avi|asf|asx|mpg|mpeg|mp4|pls|mp3|mid|wav|swf|flv|exe|zip|tar|rar|gz|tgz|bz2|uha|7z|doc|docx|xls|xlsx|pdf|iso)$ {
        gzip_static off;
        #add_header Pragma public;
        add_header Cache-Control "public, must-revalidate, proxy-revalidate";
        access_log off;
        expires 30d;
        break;
        location ~* \.(js)$ {
        access_log off;
        expires 30d;
        break;
        location ~* \.(css)$ {
        access_log off;
        expires 30d;
        break;
        location ~* \.(html|htm|txt)$ {
        access_log off;
        expires 1d;
        break;
        location ~* \.(eot|svg|ttf|woff)$ {
        access_log off;
        expires 30d;
        break;
    55,802
    12,272
    11:06 PM
  3. reallove0810
    25
    3:06 PM
    1.7.9
    5.5.41
