32 bit binaries on 64 bit OS? Repo?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Codexer, Sep 16, 2017.
  1. Codexer
    Codexer New Member
    7
    5:26 PM
    1.7
    5.5
    Is there a repo setting or similar that's preventing the installation of 32 bit binaries to run with the 64bit OS? CentOS 7.x
    E.g - yum install glibc-devel.i686
    No package glibc-devel.i686 available.
    For context, I need to install the 32 bit binaries to run SourceCMD (See here: SteamCMD - Valve Developer Community recommendation is to simply install the 32 binaries on a 64 bit machine via yum)
    So: yum install glibc.i686 libstdc++.i686
    Any help much appreciated
  2. Codexer
    Codexer New Member
    7
    5:26 PM
    1.7
    5.5
    So the solution is:
    Edit /etc/yum.conf and remove i686 from exclusions and it should work - can also add the exclusion back once upated.
    37,663
    8,241
    5:26 PM
    yes you can do it that way or disable excludes for main yum repo via command line
    yum install glibc-devel.i686 --disableexcludes=main
