Xenforo 1 Click Upgrade
Discussion in 'Forum software usage' started by frm, Jan 20, 2019.
  1. frm
    frm Member
    34
    10:44 PM
    1.15.7
    10.3.11
    Trying to figure out which files need permissions set and to what in order to use 1 click upgrade on XF using CMM / PHP-FPM.
    Anybody know?
    55,917
    12,281
    11:44 PM
  3. frm
    frm Member
    34
    10:44 PM
    1.15.7
    10.3.11
  4. frm
    frm Member
    34
    10:44 PM
    1.15.7
    10.3.11
    Xenforo Permissions
    Would src be 0660 too?
  5. JAFRI
    JAFRI New Member
    6
    6:44 PM
    nginx/1.15.9
    MariaDB 10.2.22
    same problem,
    Cannot install from archive as not all required directories are writable. Various directories must be writable by the web server user to install from an archive. In addition to the XF root directory, some or all of the following paths must be writable: js, src/addons, styles, src/XF/Repository/AddOn.php.
    XF 2.1 - One-click upgrades and add-on install/upgrade from ZIP files
    55,917
    12,281
    11:44 PM
    post #2 has link to correct permissions
  7. JAFRI
    JAFRI New Member
    6
    6:44 PM
    nginx/1.15.9
    MariaDB 10.2.22
    thanks for reply,
    but problem not solve, i use this permissions, what is wrong ?
    find /home/nginx/domains/newdomain.com/public/ -type f -print0 | xargs -0 chmod 0640
    find /home/nginx/domains/newdomain.com/public/ -type d -print0 | xargs -0 chmod 0750
    find /home/nginx/domains/newdomain.com/public/internal_data/ -type f -print0 | xargs -0 chmod 0660
    find /home/nginx/domains/newdomain.com/public/data/ -type f -print0 | xargs -0 chmod 0660
    find /home/nginx/domains/newdomain.com/public/internal_data/ -type d -print0 | xargs -0 chmod 0770
    find /home/nginx/domains/newdomain.com/public/data/ -type d -print0 | xargs -0 chmod 0770
    find /home/nginx/domains/newdomain.com/public/src/ -type f -print0 | xargs -0 chmod 0660
    find /home/nginx/domains/newdomain.com/public/src/ -type d -print0 | xargs -0 chmod 0770
    chmod 0755 /home/nginx/domains/newdomain.com/public
  8. wmtech
    wmtech Active Member
    180
    44
    3:44 PM
    chown -R nginx:nginx /home/nginx/domains/newdomain.com/public
  9. JAFRI
    JAFRI New Member
    6
    6:44 PM
    nginx/1.15.9
    MariaDB 10.2.22
    Thanks. :) now working fine.
  10. Dnyan
    Dnyan Member
    106
    24
    7:14 PM
    1.17.8
    10.3.22
    Thanks, it worked
    55,917
    12,281
    11:44 PM
    guess 5 months isn't too late :)
    Glad to hear it's working now.
  12. Dnyan
    Dnyan Member
    106
    24
    7:14 PM
    1.17.8
    10.3.22
    I did it at that time too when one click upgrade started. Then inbetween moved to another host so was trying to figure out why it was not working.
    I keep reading all new posts at here :)
